Rewiring all things entertainment
2021 320 S BD - Rewiring all things entertainment, adding 12V switch bank, adding 12V Blu-ray player, digital battery meter, and USB C charging ports. Everything will be on it's own switch so they won't suck the life out of the battery. Way it should be in a boondock version.  Next - adding an external antenna for over the air digital TV.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
  • webers3
    webers3 Member Posts: 449
    Looks like a perfect set-up to spend quality time indoors
  • SLJ
    SLJ Member Posts: 662
    Cutting done. Panel mounted. Very tight fit. Start wiring tomorrow.
    2025 Ford Ranger
  • AirBoss
    AirBoss Member Posts: 740
    Nice project.
    Guess I'd also say nuCamp uses some discretion in certain areas to keep costs down.
    San Diego, CA
    www.airbossone.com
  • SLJ
    Completed.
    Switches from left to right: Overhead lights, USB chargers, Jensen Stereo, Blu-Ray player, and TV. Digital Battery meter is on with toggle switch. None will draw battery power when switch is off. Switch LED is only lit when on and I can disable or dim any of them I choose.
    2025 Ford Ranger
  • CanadianTabber
    CanadianTabber Member Posts: 148
    Great setup..where did you get the switch panel and what model Sony is that?
    Thanks!
    Brent
    Toronto, Canada
  • SLJ
    Got the switch panel on Amazon. There's a lot of configurations to choose from. Had to move the Jensen to the right to fit it in there. It's a very tight fit and if your cutting isn't precise you'll wind up mounting everything in a panel and placing it over the spaces. That was my back-up plan if I screwed it up. The 12 volt DC SONY is a model BDP-BX370. Just cut the AC wall wart off the cord. I set it on a piece of 1" foam and there's a Velcro strip on the lip of the compartment to hold it in place.
    2025 Ford Ranger
  • tomtek
    tomtek Member Posts: 48
    Nice job on your panel.  I have a few of my switches done.  Plus unhooked step light and removed the clamshell safety solenoid.  you can also see my IR extender which extends the IR remote from outside the clamshell.
    2009 Dutchman TQ - Sold
    2021 CS-S - Enjoying the new layout
    2011 Outback 3.6r
