Lithium Battery Install
RetireeBC
I thought we would share our lithium battery install with the forum. We removed our lead acid battery to make room for a second propane tank in the plastic tub. We then installed a 100 amp Canbat lithium battery in the electrical bin. We also added a lithium charger and a solar port outlet for our 200 watt portable Go Power solar suitcase. We had the battery charge line disconnected from the 7 pin connector as we didn't want to deal with the issues that have been associated with car alternators and so on. We might consider adding a DC to DC converter in the future; but will hold off for now to see how we do with our solar and lithium charger. We added had a battery cut off placed inside the trailer. We had all the work done by knowledgeable RV technicians as we certainly don't have the required technical knowledge that I know others have on this forum.
2019 TAB 320s
Vancouver Island
4
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
