Eliminating Tab 400 Rear AC?
One night in a moment of frustration over the rear AC duct that blows at the side of my head, I removed the register and stuffed a towel in it.  Turns out this works for me temperature wise.   So my question is, are there any unintended negative consequences of blocking off this duct?  I see three approaches.  1)something more elegant than the towel that’s in it now; 2)block it at the manifold on the CoolCat; and 3)remove the duct from the manifold and let the cold air flood the compartment under the dinette seat where the CoolCat lives.
  • Verna
    Verna Member Posts: 6,876
    I would block the duct at the wall in the bedroom area. Resale value is a good reason. We all say this is our last T@B (yeah, go ahead and laugh, @ScottG!!), but sometimes life throws us a curve ball. Don’t make a change that you will have to explain to a new owner why you didn’t have time to put it back k the way it was.
    My opinion is based on seeing a lot of new buyers last year who have already sold their new T@B’s within a year of purchase.  Life changed, jobs were lost, had to follow a job, pandemic is slowed down and they can fly again—lots of valid reasons.
  • manyman297
    manyman297 Member Posts: 1,436
    I think it’s designed with three ports in mind. So blocking off one may cause too much positive pressure in the system and burn out the blower motor. Not totally sure about this though.
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • Pintoplumber
    Pintoplumber Member Posts: 182
    There may not be enough air flowing across the coil that it may ice over.
    2016 320 CS-S  1954 Ford F100  2017 Chevy suburban  2023 Chevy Silverado 1500
  • marleecamps
    marleecamps Member Posts: 179
    I also dislike cold air blowing directly on me.  By rotating the duct cover 180 degrees, the air now blows upward over my head - which works for me.
    --Marlee
    2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota
  • AirBoss
    AirBoss Member Posts: 740
    Spin the duct and/or damper it. I would be reluctant to block it entirely.
    San Diego, CA
    www.airbossone.com
  • Katydid
    Katydid Member Posts: 43
    edited August 2021
    @manyman297 How is your rear A/C register mod working out?
    2021 TAB 400BD; 2015 Audi Q5
    Boston Northshore
  • manyman297
    I haven’t modded mine. I just point it up and let the cool air fall down.
    2021 400 BD
  • rrcbov
    rrcbov Member Posts: 109
    I sent Dometic this question on their support form.   I’ll share the response when I get it.
  • rhyno
    rhyno Member Posts: 393
    edited August 2021
    Check out my diverter fix. Details here and it works great.
    https://tab-rv.vanillacommunity.com/discussion/comment/169761#Comment_169761
  • Katydid
    Thanks for the update @rhyno. It’s the one mod I’m motivated enough to do and that I might be able to accomplish.
    Boston Northshore
  • manyman297
    Ahh. Didn’t realize some people are referring to the older 400s where the duct was lower. Yeah, I can see how that could be annoying. Glad they moved that duct up.
    2021 400 BD
  • rhyno
    edited August 2021
    @manyman297 - Our 2021 has the bed's AC duct at head level. Isn't your 2021 at that same height or is nuCamp moving the AC duct up to the top again?
  • Katydid
    I have the 3 way fridge on my 2021 . I think I remember someone saying that if you have the 3 way the duct is head level and if you have a 2 way it’s higher?
    Boston Northshore
  • manyman297
    I'm losing my mind. You're right. I think your pillow threw me off as it looks like the duct is right at mattress height.
    I actually don't find its location an issue as long as the register is pointing upward. I'd rather have it there than up high. I find that when it's really hot I like to just point it straight at me to get cool quicker.
    2021 400 BD
