Victron Smart Shunt Settings for AmpereTime 100Ah Lithium Battery
rcarlson1957
Member Posts: 267
In process of changing out my stock Interstate lead acid battery with an AmpereTime 100Ah lithium battery and a portable solar install. If anyone has the same battery, can you share the correct settings for charging voltage, charge efficiency, Peuker exponent, tail current and discharge floor? Victron's manual has some generic ones and said consult manufacturer. Don't see anything anywhere where AmpereTime addresses most of it. Thanks!
2018 TAB 320S
2020 Honda Ridgeline RTL
North Texas
Trips - 50 Mileage - @67k
Here is a thread, with some other links inside, that describes the settings in a little 'real world" detail.Look for a couple of comments that also point to other lithium battery settings.
Towed by 2014 Touareg TDi1
