Mod to mount Lagun outside.
Mod to the Lagun table leg. This was done in order to facilitate clearing the lock-lever from wheel well. NOTE The lever was removed and reinstalled on the opposite side. How? .
1. Remove the black locking lever. 2.
2. Support the leg on both ends with the head of the bolt facing down.
3. Use a piece of wood to protect the threads of the bolt then using hammer, pound bolt out.
4. Flip leg over and insert bolt. I found there is no need to try to ‘fit’ the bolt into the round hole however it will help to seat it if again you support both ends of the leg and, using wood and hammer, drive the head of the bolt in.. Simply install the black lever and begin tightening.
The wall bracket is pushed off the wall about ¾ inch using two layers of plastic cut from a cutting board. Not shown is an extra piece of 2 x 4 inside the wheel well to give additional secure mounting point. The mounting bolts are #10 x 4 inch
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
