heating with battery only, any recomendations?
gullystravels
Member Posts: 27
We have a cool cat heat pump that doesn't work on battery. looking for suggestion for an alternative heater for boondocking.
we have a 2012 TAB BASIC
The Mr. Heater Buddy series is pretty popular, a friend of mine used the small one in a Meerkat trailer. They do have safe guards so they can be used inside.0
put on the kettle
2014 T@B 320 S "Sunny" - 2015 Toyota Sienna LE - British Columbia, Canada0 -
thanks for all the recommendations, a neighbor is lending me his Mr. Heater Buddy so I can try it out this week camping.
I can see using it to heat up the cabin initially but I don’t think that I would use it inside for long periods. If you do, I would make sure that the cabin is well ventilated and the CO detector is working properly. I think that would heat up the cabin with the little buddy, fill up a couple of hot water bottles, and use a “real” sleeping bag. I would not use the heater overnight.gullystravels said:thanks for all the recommendations, a neighbor is lending me his Mr. Heater Buddy so I can try it out this week camping.I’m surprised that your 2012 doesn’t have a propane furnace - I thought that was standard during that time period.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I have read that moisture can be an issue with propane vent-less heat. Anyone have an issue with that?0
Then again the Fantanstic vent can handle that. We are still learning our T@B..
Mr. Buddy Heaters are great--have used them off and on for years. I have the one that can take either 1 or 2 small propane bottles. Just make sure you either crack a window or your vent fan and as always make sure your CO detectors are working.2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab0
