Fresh water loss while traveling
johnbets
Member Posts: 8
I’m losing fresh water while traveling. There are no detectable leaks when stationary. I, and others, notice a stream of water when I’m on a steep uphill, Is this normal flow from the overflow? Can I plug the overflow outlet? It’s not an insignificant amount of water and I travel on a lot of steep grades. On my last trip I believe I lost a quarter tank!
2021 320 CSS
2021 320 CSS
John and Betsy. 2021 T@B 320 CS-S. 2018 Toyota Tacoma
Oh, forgot to say Thanks!John and Betsy. 2021 T@B 320 CS-S. 2018 Toyota Tacoma
Suggest you contact NüCamp Tech Support.
As they will know the hidden locations of overflow/etc connections.
So they should be able to say what is normal/abnormal when trailer is on a steep grade.
From the nüCamp & Forum Contracts section (on left of your screen)'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180
