Fuses ATO or ATC?
thinkingaboutit
Member Posts: 1
The operator manual for the WFCO converter specifies ATC "Littelfuse" Type 257 fuses. So far I am only able to find ATO fuses. If it matters, would someone direct me to a seller of the ATC type? Thanks.
ATC is closed and ATO is open to the environment. ATC is considered to be more weather resistant. A general example for their uses, ATC would be used under the hood of a car and ATO (or ATC) in the driver's compartment. You should be able to find ATC fuses at Amazon, Walmart, NAPA, etc.
2019 320 Boondock Edge - Sold Jan 2022 -
I ordered them from digikey.com. Shipping is reasonable.Chan - near Buffalo NY
- 915 Tips & Tricks
