Alde 3010 'Gas Failure'
It can occur due to low voltage. How is the battery?
https://tab-rv.vanillacommunity.com/discussion/comment/115538#Comment_115538
We experienced essentially the same issue with our Alde 3010, 2014 320. Like you, I checked the fuses (good), voltage, (good), LP tank (full), unplugged and reconnected power to the Alde, checked fridge on LP (good), and stove on LP (good).
After a few attempts our dealer was not able to fix the issue. They replaced both the pressure regulator and the thermostat. Neither solved our problem. I ended up working directly with Alde and they helped me diagnosis the problem as an intermittent issue with the gas solenoid.
I replaced the solenoid myself and have tested the Alde system three times since the repair and it’s been working great. We’re in Minnesota and I’ve ran it in temps ranging from 20 to 50 degrees.
The part number is 3010622 and it runs $116.70. I bought the part directly from Alde although my understanding is that they’ve change their approach and you now have to go through a dealer. I hope you will find this information useful.
BTW if you go to YouTube and search "replace Alde 3010 solenoid" you will find a video that shows you how to replace. It took me about 30 minutes.
2014 T@B-S
2019 Honda Ridgeline, AWD, V6, 5,000 lbs towing capacity
Minnesota2 -
Glycol level?
The glycol level is good and the battery is a new Battleborn and is excellent.Spruce1, thanks for the info. I will check it out.Thanks0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
