Winterizing and battery disconnect question
xdr
Member Posts: 289
We would just like to verify that we are using the battery disconnect switch on our 2021 400 correctly.
We have winterized the camper and it is covered so solar is not charging it. We are unplugging from house power and disconnecting the battery using the switch. Should we expect the battery to maintain the charge until the spring? We have the Victron app and will monitor it but want to make sure we are doing this correctly.
Thank you,
mary
mary
2021 2024 T@b 400 Black Canyon, 2020 Ram Rebel 1500
One man, one woman, two small dogs and a sense of humor.
If you charged the battery fully, then turned off the inverter and the battery switch, there should be little self discharge. Just keep an eye on it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thank you for your quick reply! We did just as you said and will monitor it.2021 2024 T@b 400 Black Canyon, 2020 Ram Rebel 1500
- 915 Tips & Tricks
