2021 T@B 400 - blowout-only winterizing for water pump
rhynorhyno Member Posts: 394
After blowing out the lines and fixtures, I noticed that I can still hear some sputtering when I run the pump. Can I switch the Nautilus to "Winterize" mode and use compressed air to blow out the pump while it is running?
  • RMoRMo Member Posts: 162
    As mentioned in other threads, you may want to run a little antifreeze through the pump and into the toilet to preserve a plastic fitting in the toilet that seems to crack if not entirely free of water.  I think you can do this without running antifreeze into the other sink lines (at least that's what I'll believe until I un-winterize and see if I've avoided getting antifreeze that lingers in my main sink line).
    2019 T@B 400 (for sale)
    2017 Highlander Limited
