Timbren Axle-less suspension on a 2006 T@B T-16
SS_Minow
SS_Minow Member Posts: 2
edited December 2021 in Trailer & Towing
I wanted to check and find out if any folks have installed Timbren axleless suspension on there T@B? I have a 2006 T@B T-16, and plan on this project. But wanted to get some feedback.
Thanks-
(Title edited for search purposes.  Moderator)
  • WayneW
    WayneW Member Posts: 263
    I don’t recall seeing anything about installing Timbren suspension on a T@B but there are several threads on the T@G forum that discuss it. That might be a starting point. It looks like an interesting option.
    2021 320S BD
    2017 F-150
    Coeur d'Alene, Idaho
  • SS_Minow
    Thanks Wayne; appreciate the feedback. I'll check it out👍
  • gderrick
    gderrick Member Posts: 15
    I wonder if the light weight C channel frames on the older Dutchmen T@B is up to the task.  When I mounted a clamp on spare tire carrier to the frame just in front of the propane holder, I was amazed at how much the frame would twist bouncing the tire around when I bumped the tire by hand.  I decided against it.  I think these frame rails need to be linked together with the axle spanning them - we all know that our floors aren't strong enough to hold things together.
    I could be wrong but I felt I should say something.
    Good luck.
    2006 T@B
