2008 dutchman t@b cool cat service AC
SweetPea
Member Posts: 5
I have a 2008 Dutchman T@B I inheirited 2017 has been used once or twice every year. Cool cat. Ac/ heat pump. acting a bit off last summer.2020. Cooling fine then blowing warm. Does anyone know where i could get this serviced in Charleston, South Carolina? Or how to just add freon? Thank you.
If you can't get it to stay on cool, but switches to warm, than that is a nonrepairable problem. You "might" try replacing the thermostat. Some folks have had success doing that.Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
MOUSE-KE-T@B is correct. I experienced the same issue in the Summer of 2020 on my 2008 Dutchmen T@B. I replaced the thermostat and it worked for me. I consulted with an RV A/C repairman and he said that these units are not serviceable. Freon cannot be filled but the entire unit needs to be replaced.
TV - 2004 Toyota 4Runner V6 Sport Edition
- 916 Introductions
- 72 Teardrop Groups & Links
