2008 dutchman t@b cool cat service AC
I have a 2008 Dutchman T@B I inheirited 2017 has been used once or twice every year. Cool cat. Ac/ heat pump. acting a bit off last summer.2020. Cooling fine then blowing warm. Does anyone know where i could get this serviced in  Charleston, South Carolina? Or how to just add freon? Thank you.
  • Mouseketab
    Mouseketab Member Posts: 1,260
    If you can't get it to stay on cool, but switches to warm, than that is a nonrepairable problem. You "might" try replacing the thermostat. Some folks have had success doing that.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • gtstoys
    gtstoys Member Posts: 8
    MOUSE-KE-T@B is correct.  I experienced the same issue in the Summer of 2020 on my 2008 Dutchmen T@B.  I replaced the thermostat and it worked for me.  I consulted with an RV A/C repairman and he said that these units are not serviceable.  Freon cannot be filled but the entire unit needs to be replaced.
     B)  TV - 2004 Toyota 4Runner V6 Sport Edition
