Charging with a Jackery Panel.
2022 T@B 320-S Boondock Edition
2022 Outback Limited XT
SOK 100ah LiFeP04 Battery
I have the same set-up as what you are planning to do, here are the items I purchased to do this:
I bought inexpensive PWM charge controller, MPPT would be better.
I cut-off the female/male connector on the SolarEnz cable so that this end of the cable is connected to the charge controller and the 8mm end connects to the SolarSaga.
I cut-off one end of the Elector extension cable so it connects to the charge controller and the other end connects to the external socket on the T@B.
My 320s already had the external solar charge socket so I don't have the detail on what you need but I am sure you will find it on Amazon
I used this set-up last season and it worked very well charging the T@B battery or the Jackery
2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut -
The post above doesn't spell it out but the Jackery panel relies on the charge controller in the Jackery box so it doesn't have a controller mounted to it. Which is different from most mobile solar panel setups that have an integrated controller.
A PWM controller is fine for a 100W panel but make sure it has a LiFePo setting. -
That was my understanding also though I have recently been told that if my Jackery Solar Sage 100 watt panel had outputs to charge a phone as well as USB devices then it does have an onboard controller. Your thoughts?Grumpy_G said:The post above doesn't spell it out but the Jackery panel relies on the charge controller in the Jackery box so it doesn't have a controller mounted to it. Which is different from most mobile solar panel setups that have an integrated controller.
A PWM controller is fine for a 100W panel but make sure it has a LiFePo setting.2022 T@B 320-S Boondock Edition
I have 2 jackery solar saga 100 panels. They do not have a charge controller so you will want one if you are going to use it to charge your battery. They can charge cell phones without a charge controller because most modern cell phones can not be overcharged. They kind of act as their own controller. Once they hit 100% they stop receiving a charge. But your trailer battery is not like a cell phone and can be over charged. If you want to use the solar saga to charge your trailer then you need to get a controller to run it through.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
@Grumpy_G the Renogy Wanderer has LiFePo setting2017 T@B 320S 2019 Jeep Cherokee - Southern Connecticut
So does the Victron MPPT75/10 and 75/15. The Blue 75/10 is all you need for a single 100 watt panel. But the 75/15 is only a few $ more and will work with both a single 100 Watt or 200 watt setup. Both have a blue tooth smart phone app to setup and control the units.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 915 Tips & Tricks
