Tab 400 2021. Rain Cover Options.
riverchemistry
Member Posts: 9
I am looking into rain cover options for mine and can’t figure out which rain cover is going to fit. On the cover here, it reads Dometic. The fan is a drop in Max air model. Could anyone recommend where I could pick one up online?
@riverchemistry, I don't know for sure if it will work with the MaxxAir fan and the Dometic lid depicted in your photos, but take a look at the the Dometic Ultra Breeze #U1400 cover. You can get it in gray smoke (#U1400GRS) through eTrailer.com. However, if you want black smoke (#U1400BLS) or white (#U1400WHS), you must go through a Dometic dealer (at least that is what I had to do when I purchased mine.) I suspect it will work for you, because you have the plastic attachment tabs on each side of the vent.
Read through the entire discussion thread included below to see if it provides you with any helpful info. It includes a discussion about the attachment tabs, which provide a very quick and easy installation. If you like the Ultra Breeze cover and believe it will work with your current fan/cover, be sure to read the issues I encountered with purchasing it.
https://tab-rv.vanillacommunity.com/discussion/comment/111606#Comment_111606
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
@Bayliss Wow, I read your story. What a pain, but all that experience may save me a lot of time and I thank you for it. I see etrailer has this smoke grey. Is this what you meant? If there’s another model could you dm me or post it here? I’ll see if I can get it online. Much appreciated.
Is this the one?
https://www.etrailer.com/RV-Vents-and-Fans/Fantastic-Vent/FVU1400GRS.html
@riverchemistry, "yes," that is the cover in "grey smoke." I could not find the other colors through an online retailer. I purchased the black smoke via an RV dealer that had to order it through their supplier.2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ)0
- 75 Teardrop Groups & Links
- 916 Tips & Tricks
