My Fall/Winter T@B projects I've completed
SLJ
SLJ Member Posts: 665
Here are the major ones I completed over the Fall/Winter to our 2021 320S Boondock, still a few to go.
1) Changed battery to larger AGM and moved inside (more secure and lightened the tongue).
2) Put all the parasitic draws on the battery on a switch panel (ceiling LEDs, USB ports, TV, radio, etc.) and added a Blue-Ray player and a voltmeter for the battery.
3) Changed the low fixed faucet to a higher swivel faucet.
4) Added a table bracket by the door so the table can be used as more counter space and a headboard at night.
5) Changed the outside light to red and added red LED strips with a lower switch by the door for better night vision to use when I'm using the telescope and camping at astronomy campgrounds.
6) Added a fixed telescoping omnidirectional TV antenna (no holes in the roof) so there's no set up to use the TV when in parking lots or rest areas.
7) Added a bathroom fan in the outside bathroom wall (drilling a large hole in the side of your new camper is not for the weak hearted).
8) Added a Garmin backup camera to the T@B that uses my Garmin GPS as the display.
More info on each: https://solocanoes.com/camper.htm
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
  • ChanW
    ChanW Member Posts: 3,171
    edited April 2022
    @SLJ, thank you for doing all the work for me!
    I've been wanting to put in a bathroom fan for a long time, couldn't find the fan, and you even figured out how to get the wire through the foam wall!
    Excellent!
    Looks good!
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • fstop32
    fstop32 Member Posts: 391
    Nice work @SLJ!  I've been wanting to add a bath exhaust fan to my 2015.  Did you cover that install in a separate post?  I'd love to know the fan you used and tidbits on getting the wire to it.
    DaveR middleTN - 2015 320S  /  TV 2003 Tundra 4x4
  • SLJ
    Yes, more details here: https://solocanoes.com/camper.htm
    2025 Ford Ranger
  • jgriz
    jgriz Member Posts: 10
    Cool astronomy mods. If you make the trip to the Grand Canyon Star Party (South Rim) this June I'd love to see them! I will be there with my 2022 320S and 12" dob.
    2022 T@B 320 S Boondock
