Norcold 3 way - 2014 T@b propane not working
Finchy
Finchy Member Posts: 41
Hi, Any quick fixes that anyone has stumbled upon? Electric works, propane does not. Green light comes on and it sounds like it should be working but merely generates heat. Fuses are good. I've asked this before but it was several years back. What is the replacement solution. Seems like the Norcold 3 way just isn't cutting it. Thanks!
2019 Tacoma Off Road
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain
  • Grumpy_G
    Grumpy_G Member Posts: 746
    Somewhat contrary to the prevailing sentiment I'm a fan of the propane fridges because they have virtually no battery drain for extended boondocking. On the model used in the T@b the fridge temperature is regulated through the size of the gas flame, this is different from most larger RV fridges where the flame is turned on and off. If the fridge has poor cooling on gas (too little flame) it could be the gas valve isn't working correctly or there is a restriction somewhere at the nozzle or the flue.
