How to remove water spots?
xdr
xdr Posts: 288
We have our camper parked next to the lawn and keep it covered until we start getting it ready for spring/summer travel. We had a sprinkler that was splashing a bit into the side of the camper and we didn’t realize it until it left water marks. They are on the driver side and porthole windows.
Any idea of a product or technique to get the spots off?
Follow up question- has anyone had their camper ceramic coated or done it themselves?
2021 2024 T@b 400 Black Canyon, 2020 Ram Rebel 1500
One man, one woman, two small dogs and a sense of humor.
  • bergger
    bergger Posts: 1,077
    I would just wash and wax the trailer. Then use some McGuires plastic cleaner followed by their plastic polish on the windows. I just cleaned our windows yesterday with that and they look fantastic.
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
  • RVMike
    RVMike Posts: 30
    Mike and Priscilla, White Salmon, WA
    2020 T@B 320 S Boondock Edge, 2020 Subaru Outback
  • RVMike
    RVMike Posts: 30
    A few years ago I did the same thing with my Navion motorhome, the tail hung over the grass and got nailed by the sprinklers.  I used a product called "Hot Sauce" to remove the water spots.  It worked OK, but not great.
  • manyman297
    manyman297 Posts: 1,436
    Straight vinegar works really well and is relatively harmless. I always start with vinegar and then move onto stronger chemicals if it doesn't remove it. Since you'll be wiping the windows just use a soft cloth and very little pressure.
    2021 400 BD
    2020 Tacoma TRD Off-Road
  • Mickerly
    Mickerly Posts: 500
    I agree with the vinegar. After the windows are clean Any spray and wipe wax will work. We use Mother's brand, but others are equally good.
    I would use Graphene or a paste car wax for the rest of the trailer. Both work well. They are easier to apply than ceramic and last longer.
    2018 320CS-S
    "Just Enough"
  • xdr
    xdr Posts: 288
    @Mickerly Do you use wax on your windows? I’m not familiar with Mother’s brand. I’m assuming it is for the sides and the windows?
    I think we will start with the vinegar for sure. After the side is clean we would like to put some kind of wax/protectant to help make cleaning easier.
    Thank you for the suggestions!
  • Mickerly
    Mickerly Posts: 500
    Mother's and Meguiar's are the two better selling car products. Normally I use Mother's, but last time Meguiar's was discounted. I'm currently using Meguiar's Quick Wax. You spray it on while the trailer is still wet after washing. Then dry. It leaves a thin coating of wax without using any abrasives. There is also a small UV protectant in the wax.
    Yes, I use it on windows as well as the rest of the trailer. It makes them very easy to clean, bugs don't stick.
    2018 320CS-S
    "Just Enough"
  • RVMike
    RVMike Posts: 30
    Yes, I have used vinegar. it didn't  make of a dent on the water spots.  Hot Sause did. I'm not saying that it is great, but it caused the waterspots to go away with enough applications.
  • Mickerly
    Mickerly Posts: 500
    When vinegar doesn't work move to something stronger. CLR or a bathroom cleaner. Be careful. The windows are acrylic. Unless you want to do a lot of buffing, don't use anything abrasive.
    2018 320CS-S
    "Just Enough"
