Can you use this 15 to 30 adapter to charge your batteries?
    qhumberd Administrator, Moderator Posts: 835
    Just what we use when at home. We are on a 20 amp home circuit breaker, but that will run all systems in our 400, as long as a/c and microwave are not simultaneously started. You basic converter 12V circuits are all good
    MuttonChops Member Posts: 1,975
    @CCC;
    Short answer is Yes you can charge your battery while plugged into a home 15/20A circuit.
    Longer answer:
     ++  Typical WFCO 8735 Power Center draws 5A at 120VAC Maximum
             That 5A includes the Power Center Battery Charger and
              the Power Center powering all the T@B 12VDC stuff via the 12VDC fuse panel
      ++  Depending on what other things are using the house 15/20A circuit you should also be
              able to run the Alde on 'electric level "1"  which is 1500W' or about 12.5A
