T@B 320S Floorplan Storage Map Template
rcuomo
rcuomo Member Posts: 321
edited May 2022 in Tips & Tricks
Hi All,
I'm sharing the Word doc template I used to create my 2018 320S storage map.  One file is my actual map and the other file is the template that you can personalize by adding text boxes as needed (Arial font size 8).  I carry a water tight storage box either in the truck bed or inside the trailer so it is included.  I have added two SAE receptacles to the tub, one to charge the battery and another with reverse polarity to plug in my Renogy suitcase.  Regarding my tire air pressure note, I have switched out my tires to Goodyear Endurance and run 55# air pressure.  OEM tire air pressure is 50#.  Always looking for suggestions/ideas from the group!
Huntington LI
  • Bayliss
    Bayliss Member Posts: 1,517
    Nice job, @rcuomo.  Thanks for sharing.
    Greg & Marlene (Tucson, AZ)
