Carry extra water front Tab BD
homerd
homerd Member Posts: 37
You can fit 2 reliant 7 gallon water boxes. They fit pretty good. From Walmart $20 each
2022 Tab 320S Boodock
2012 Toyota 4Runner SR5
2013 KZ Durango 336RE
2013 Chevrolet 2500HD LTZ Duramax
Akron, Ohio Summer/Fall and out camping
Largo, Florida Winter
  • Grumpy_G
    Grumpy_G Member Posts: 784
    Nice. Those with lighter tow vehicles need to keep in mind it adds over 100 lbs to the tongue close to the hitch point.
  • homerd
    Yes, but I mounted my rear tire on the back of my tab in a carrier so I wanted some hitch weight!
  • AnOldUR
    AnOldUR Member Posts: 1,759
    homerd said:
    … I mounted my rear tire on the back …
    Sounds like you may be OK, but if you can, please measure your actual tongue weight with the containers full and report back here so that others know what to expect with this setup. Thanks!
  • homerd
    Without water, weighed at 207#. All gear in boxes and trailer including 10# full propane bottle. With H20 will be around 325#. I like it
  • homerd
    10# is additional bottle
