Early Modification Update = Seeking Comments on Next Steps
Background:
There are a few Forum threads and one lengthy Facebook post discussing increasing the fresh air to the Window A/C compressor and heat exchanger. The goal being to increase the cooling provided by the 5K Btu unit during >90+ ambient temperatures days.
nüCamp's original window A/C builds had no additional fresh air intakes to the unit. They quickly changed the builds to include a standard RV Waste Vent Pipe Cap and 4-inch fan to pull fresh air into the A/C cabinet. This solution works well (enough) but the A/C still has cabin cooling issues on super hot days.
Issue:
The author of the Facebook post for increasing the fresh air volume decided to install a fairly large square vent replacing the original Waste Vent which included cutting a big hole and cutting out one aluminum structural cross-beam.
The Waster Vent only provides a 1.77 square inches open for fresh air. While the 4-inch fan does increase the total amount of air entering the cabinet it is still limited.
My Approach:
I'm in the process of installing an ~4-inch vent with 14.2 square inches open for fresh air flow. Without the fan changing from the 1.5-inch Waste vent to the 4-inch Vent will increase the available fresh air 8X. Plus I will keep the 4-inch fan in place.
This approach will increase the air flow while not reducing the roof structural support.
Status:
Here is a comparison of the standard vs. the larger fresh air source.
Questions for Forum Members:
1) As currently planned there will be no water trap.
Wind blown rain could enter the new vent.
However, this is a Window A/C unit . . . designed to have most of its body exposed to rain and wind.
So I'm thinking - - - no big deal - - - any rain water will drain out of the drip pan.
Forum: Am I being reasonable?
2) Bug Screen. The original Waste Vent has a bug screen. While it will stop bigger bugs it also reduces
the real air flow cross-section. At this time I do not plan to include a bug screen.
Forum: Should I attempt to install some type of screen?
If so how - - - maybe a flat screen at top of 4-inch PVC coupler (that Vent Hood attaches to) . . .
3) Orientation of Vent. I'm using a RadonAway 76002 4-inch vent cap on this modification.
The '76002' is not round. Should I install it so normal driving wind passes through the vent.
Which means much more rain water will be able to enter while driving.
Or should it be installed left-2-right, wind rain won't enter driving but it provides more air resistance.
4) I am wondering if the small pop-rivets holding the 'grill' to the base will with stand 65 MPH
driving winds. I've added cotter pins to the pop-rivets, mandrel is ~1/16 inch and one was already gone.
I purchased "Floor vent deflectors" from ACE Hardware. Their magnets stick to the screws on the outside vent. By preventing the hot exhaust air from re-entering with the cooling air, you can significantly increase the coldness of the air in the cabin. There are several other posts on separating the hot exhaust from the cold intake air.
"Just Enough"
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Greg & Marlene (Tucson, AZ)
This is a low quality (zoomed) picture of the Vents mounted on Dales's trailer.
Adventures: 54 Nights: 341 Towing Miles 43,780
I saw the opening in the roof vent was too small. I was thinking about opening it up to match the fan. I just hadn't figured out the cover yet. I have another project going now. This was for next year.
Getting the hot air out and cool air in is the key to good performance. The unit does a good job of exhausting the hot air, unfortunately, it mixes with the incoming cooling air. A better roof vent is an excellent solution. The stock vent doesn't allow enough air movement. The two solutions together are better than either alone.
"Just Enough"
That helps keep the floor vents in place with light wind . . . but they still fall off time-2-time.
T@B Forum | nuCamp RV
https://tabforum.nucamprv.com/#/discussion/15627/danby-ac-hot-air-venting
After centering the 4-inch fan at the down-tube. The speed of the fan seems faster and the volume of air blowing down is a huge difference from the original 1.5-inch vent opening.
Will see if larger vent stays in place and helps any over the next year or so.
Side Note on question # 3 {and just for fun}:
The left-to-right placement provides a rounder wind profile than fore-2-aft.
July 16th Mini-Update
Today is a warmer day with 3PM ambient over 90F.
Trailer has been in the sun since 10'ism A.M. without its storage cover.
About 25-minutes ago I opened the trailer and turned on the A/C.
Cabin reference thermometer was 93F
After the 25-minutes (pre-cooling before I start cleaning up an earlier project)
Cabin reference thermometer was 85F, with A/C set on Low One Snowflake Cooling.
So I consider this a positive indication the A/C likes having a greater volume of fresh compressor & heat exchanger air.
