Valterra 64" hose carrier
bfeeny
Member Posts: 35
Just bought one of these for my 2018 CS-S. Looks like it ca only go on the curb side along the frame. What is the best way to attach? Thanks
Can't speak for your specific model, but I used several super long zipties to secure mine underneath the trailer tongue and frame of my 400. I check them periodically for wear and tear but so far going strong.--Marlee
2021 Tab400 Boondock; TV 2025 Jeep Grand Cherokee Limited; Minnesota2 -
You can attach with screws using the holes at the top of the bracket. Then secure with UV resistant zip ties like Marlee camps did.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
Installed on passenger side using three adjustable hose clamps. It's long enough to go around the frame. The upper screw holes on the hose carrier are the only ones that will line up with the frame and 2 screws and zip ties are not going to keep it there long term. https://www.homedepot.com/p/Everbilt-6-in-Galvanized-Steel-Worm-Gear-Clamp-MC6HD/2036265090
Lots of threads with how to mount the sewer hose holder. Link under image goes to the post.
Towed by 2014 Touareg TDi1 -
Thanks very much for the info. I ended up using 3x adjustable black rubber tarp tie downs and using the upper screw hole in the hose carrier near the hitch to mount it into the frame. I was nervous to use the upper screw hole near the step because the frame was covered by the under belly.0
We have had it mounted on our frame with 2 screws and 3 zip ties for 5 years. Remains sturdy and intact.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
