Sink or faucet change
Simplysteve
Member Posts: 15
HI,
I have a 2021 T@B 400, just received a sink from a 2022, one that has the new faucet.
Has anyone made this change?
Is the faucet swap possible or should I swap the entire assembly?
Thanks
Thanks
I've got a 2021 400 and have been in a 2022 with the new faucet. Looking at them both it appears the sink is identical and just the faucet has been changed. I have not done the change but I believe you should be able to just swap out the faucet and leave the existing sink in place.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
You may find that it may be easier to replace the faucet if you remove the sink first. Something to consider when you're under there.Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA -
If you already have the new sink with the new faucet already installed, the easiest might be o just swap out the sink and faucet in one go…
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
- 919 Introductions
- 406 Service/Maintenance & Recall Notices
