I get no heat just setting the "lightening bolts" column to the max setting and the thermostat set to the max.
I do get a 'click' and apparent glycol movement thru the system when I ALSO choose the setting that has a picture of the Water AND Heat in the other column….Is it OK to use this setting w/o any water in the tank? I assume the glycol heating does no damage as it circulates in its own system…
Thanks,
Chris
2015 Tab - Q
Chris and Phil - Sally D., 2015 Q Maxx, Toyota 4Runner, Sidney, BC, CANADA
0 ·
Benderenns -- Did you try running the system with the slider to position J (heat only)? To get heat, you need to have the circulation pump on, too, which is controlled by the third slider. If the slider is on Position H, it is OFF. Turn the third slider to setting I for heat and hot water or setting J for heat only. The heat is controlled by the room temperature, sort of like your home furnace works. Increase the setting with Knob K to override the room temperature in order for the heat to kick in.
The Alde should operate on either shore power or LP. I was able to get heat on shore power, but I have not tried it on LP only.
I admit it is confusing.
~X(Benderenns -- The water pump switch on the wall is to be used only if you are not connected to city water, and it will pump water from your fresh water tank through the lines. Do not run the pump with less than 2 inches of water in the fresh water tank. You might want to try filling the fresh water tank and turning on the pump to get some water into your lines, if you haven't already done that. (Water is not required to operate the heating portion of the Alde system.)
As I understand it, the circulation pump for the Alde is activated from the control panel on the wall. I think I know what you are saying about choosing water only. I don't have the diagram in front of me, but just choose the icon for water only if that's what you want. I believe "hot water only" will also work if you have the setting on both heat and water, and like you say, just turn the thermostat down.
A couple other things to check: Is your inline fuse to your battery okay? Are your main breaker fuses okay? Is your glycol level okay on your overflow tank? If you still can't get it to work, perhaps your Alde fuses are blown. There are two of them located underneath the gray cover of the Alde, encased in a green plastic holder. Pop them out to check if the filament is broken. I took one of my fuses to Radio Shack to get several replacement fuses "just in case" it blows. (I posted a picture of the green Alde fuse box on March 9th under the Alde discussion.) I have the specific fuse number for the Alde fuse, and I'll post it up after I get home from work.
If all this fails, perhaps you can call your dealer to walk you though it before you make the trek back with T@B.
Let us know if any of this works.
:-??The specific fuse to get for the Alde is F3.15AL 250 VLAC, 5 x 20 mm. These are slow-blow fuses for sensitive electronics. I got some from Radio Shack. Very inexpensive.
The settings we used were two lightning bolts, slider on "water and furnace", and the temp knob set to the cicle (22 degree Celsius).
I do think I will bebgetting a fan for under the bed (along with a much denser mattress pad than our eggshell, but that's another thread!)
J.D. & Sue
Hi, DurangoT@B -- I'm glad you are getting your Alde up and going. I agree that LG has the best customer service I have ever experienced. I had to call LG to get some questions answered about the Alde, and I found Ed Kaufman to be super-accommodating.
So, I stand corrected, as it is the fast acting fuse F3.15Al 250VLAC that the Alde should have. I did find some in stock at Radio Shack, but I don't think all of their stores carries them. Here's the kind I bought. I believe the "F" in front of the description indicates it is fast acting. http://www.radioshack.com/product/index.jsp?productId=2103762&znt_campaign=Category_CMS&znt_source=CAT&znt_medium=RSCOM&znt_content=CT2032234
Transplanted Hoosier in Richmond, VA
Go Colts!
Hi Bill, I had the same thing occur last weekend, here in the Florida heat, with my SS (black strip flailing lose behind me). I pulled over and worked it back into the channel. Did the Shoe Goo hold? I am also thinking about securing it using washers at the two anchor points (front and back of the TD). 'Anybody else done this? I think it would prevent "pull through" of the warmed up rubber off the bolt heads holding this strip to the frame.
Hi, Judy -- Put the rear seats in the UP position. Lift up the driver's side seat bench and you will see the Alde. There is a grey/silver box which has a lid on it that you can open. You will see a green fuse box which houses the Alde fuses in it. (I posted a picture of it earlier this year.) There are two glass fuses that will pop out easily, and BTW, it doesn't matter which way the fuses are inserted!!! The screw-down compartment in the back has the glycol reservoir in it. I keep my compartment unscrewed so I can check my glycol fluid on a regular basis.
https://us.v-cdn.net/5021717/uploads/FileUpload/2e/c5669026888a444f4579673ccda3b4.jpg
Hope this helps.
