using the tv in tab 320cs s
javaborgia
Member Posts: 3
how can i connect my laptop to the tv to stream movies, etc.?
you should be able to plug into the hdmi input of the jensen then set tv to hdmiUltimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California1 -
What year T@B?javaborgia said:how can i connect my laptop to the tv to stream movies, etc.?San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
@jbajor My UT is at the dealer getting a few warranty items fixed. One of those is that when I plug my streaming device (Fire Stick) into the HDMI port on the Jensen, nothing shows up on the TV. I do get audio on the speakers though. Both are set to HDMI. It works fine when plugged directly into the TV. It seems your pass thourgh works fine. I wanted to confirm because when I dropped it off at the dealer the service lady claimed that it deosn't work that way. I disputed that because it seems pretty clear from the manual that it should.Ultimate Toys Teardrop
Jeep Grand Cherokee
Dallas, TX Area0 -
Which Jensen head unit do you have? The JWM22 has only one HDMI out. I would pull out the head unit to look at the connections.Brian56 said:@jbajor one more clarification. Do both of your TVs get a HDMI signal from the Jensen? Neither of mine do.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
I will take a photo for you... I have an appleTV plugged into the Jensen and use it to stream... It does support both tv'sUltimate Toys Teardrop Camper
Volvo XC-40
SF Bay Area, California0
