using the tv in tab 320cs s
how can i connect my laptop to the tv to stream movies, etc.?
  • jbajor
    jbajor Member Posts: 233
    you should be able to plug into the hdmi input of the jensen then set tv to hdmi
    Ultimate Toys Teardrop Camper
    Volvo XC-40
    SF Bay Area, California
  • Marceline
    Marceline Member Posts: 1,758
    What year T@B?
  • Brian56
    Brian56 Member Posts: 23
    @jbajor My UT is at the dealer getting a few warranty items fixed. One of those is that when I plug my streaming device (Fire Stick) into the HDMI port on the Jensen, nothing shows up on the TV. I do get audio on the speakers though. Both are set to HDMI. It works fine when plugged directly into the TV. It seems your pass thourgh works fine. I wanted to confirm because when I dropped it off at the dealer the service lady claimed that it deosn't work that way. I disputed that because it seems pretty clear from the manual that it should.
    Jeep Grand Cherokee
    Dallas, TX Area
  • Brian56
    @jbajor one more clarification. Do both of your TVs get a HDMI signal from the Jensen? Neither of mine do.
    Jeep Grand Cherokee
    Dallas, TX Area
  • Marceline
    Which Jensen head unit do you have? The JWM22 has only one HDMI out. I would pull out the head unit to look at the connections.
  • jbajor
    I will take a photo for you...  I have an appleTV plugged into the Jensen and use it to stream...  It does support both tv's
    Volvo XC-40
