New Bike Rack
Basil48192
Member Posts: 437
Finally decided on a bike rack arrangement. I bought the Swagman Traveler XC2 (RV Approved) and bought the 90 degree riser separately. I was worried about the turn radius...but never had a problem on my initial trip. I think it might hit the propane tub if I 'jack-knifed' it backing up on a decline. But it's so easy to use that I would just remove the bike if I was in that situation. It's easy to load for a 'vertically-challenged' person like me. The down-sides: I cannot open the tailgate of my truck fully when it's in place and you have to remove the hitch mount to remove the riser bar.
@Basil48192
Which 90 degree riser did you use for this?2022 T@B 400 Boondock
South Jersey -
Can you show another picture how the bent tube is attached to the receiver? Thanks‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI -
@rcuomo it looks like it just slides over the receiver tube and fastened so it does not move around.
Thanks I have the same carrier and I have to see if I have enough of space on my receiver without compromising the hitch capacity.‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI -
@rcuomo
Yes. It just slides over the receiver tube. It has two, 1/2"Ø nuts welded to the bottom. A couple of bolts are threaded through the nuts and basically 'clamp' the riser to the receiver tube. It's pretty secure. I used longer, all-thread bolt on the right so I could add a locknut as well (will change the other one when I get back to the hardware store!). The U-bolt to the right is just my hitch tightener...which is a game-changer. -
What brand receiver tube are you using? It looks to be longer than the standard length I’m using on my Ridgeline.
Huntington LI -
Darn, looked on their website and didn’t see it before I asked you. Have to dig deeper. Thanks!‘18 Tab 320S- mfg’d 4/17, acquired 9/17
Huntington LI -
@Basil48192, I picked up on your comment “ The U-bolt to the right is just my hitch tightener...which is a game-changer” and did some research. I must say I did not know such a thing existed. Thanks for the subtle information as it was a game changer for me as well. Purchased one installed it and towing seems smoother and much quieter. I rank this as my best $13.00 purchase/upgrade to date.Thanks for sharing2020 TAB 320 U
TV 2025 Telluride X Type -
I've been using the Swagman XCS2 for over 2 years on my 2018 CS-S with a 10" tow bar. Very happy with the carrier. Had a minor warranty issue with the hitch and Swagman promptly looked after the problem. A very good company with quality products.
- 919 Introductions
- 405 Service/Maintenance & Recall Notices
