Rain water inside
We purchased a  2021 320S Boondock new from dealer last year. This is the first summer pulling in the rain. The whole floor is soaked inside! Help!!
  • Dereco
    Dereco Member Posts: 95
    edited September 2022
    Just the floor, or the table and side benches too? If not, that eliminates roof vent leak. Next I would check water tank under sink....
    Denny16 Member Posts: 5,431
    Check to see if the door fits tight when closed, if not, rain could have entered through the loose door seal?
  • Yoshi_TAB
    Yoshi_TAB Member Posts: 581
    Hi, As a suggestion, once everything is dry, use a garden hose on spray setting  and go around the TAB until you see where it's coming in.  You may have to spray at many angles/directions from completely underneath to the top.  I had read somewhere where the wheel wells were a source of water from rain on other TABS.....good luck
    2025 360 CS
    Southern Maryland
