What model isotherm is in 2023 T@B 400?
jimcenname
Member Posts: 346
I'm contemplating switching to an isotherm 2-way frig from the Norcold 3-way in my 2019 T@B 400. The Norcold works well, I live in my 400 and it's been running almost continuously for 3 years. But I'd like to move away from propane. I can't find the model of isotherm installed in the 2023 T@B 400s. The factory's been slow to respond. Do you know?
2019 T@B400
Southern California
Full-timer since 2019
Southern California
It is the Isotherm Cruise 130 Elegance 4.6 cu ft AC/DC with the black front.
https://www.westmarine.com/isotherm-cruise-130-elegance-black-4.6-cu.ft.-ac-dc-black-door-3-sided-flange-18609503.html
Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S -
Factory has been on their annual Xmas break.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Here ya go. Taken from a 2023 400.
2021 T@b 400 BD "Vixen Gail"
Leadville Colorado -
@bergger, thanks for the label, that gives me the power requirements.2019 T@B400
Southern California
Full-timer since 2019 -
You may have to alter the hole left by removal of 3-way. The Isotherm Freeline 115 fit nearly perfectly. Some trim was added and insulation stuffed to assure a good seal. I think the Cruise Elegance 130 may be slightly bigger than the cutout.
2020 T@B 400 BDL towed with 2019 Nissan Frontier Pro-4X Tucson, AZ -
@johnfconway, nuCamp will retrofit the isotherm for me so I will stick with the model they use. My 2019 T@B 400 doesn't have solar, and I don't want to add it, I am not a dry camper, and I want to be sure the standard AGM batteries can power the Isotherm while I travel and maybe do one overnight stop with no shore power. And since I spend a lot of time in the southwest I want the fridge to work well in 100 degree temps. My Norcold 3-way does work well. Thanks for your comment.2019 T@B400
Southern California
The 2023 tab400 isotherm refrigerator is 12v ,not a 2 way.
the manual states that it will cool to 5c. Mine will cool to 5c on max setting of 7.
HOWEVER, every fridge should cool below 4 (40f) on a middle setting.
other 12 volt brands will cool properly. Not sure if it’s only my fridge or a general problem -
I have the same issue as Phillip. 2023 400 Isotherm has to be set between 6-7(max) to keep temp at 40F. Outside temp has varied from 50-90, with very low humidity. Anyone else have this issue? Any suggestions?2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
