For those using a Jeep Wrangler to tow a TAB 320S Boondock - what has your experience been? Interested on MPG when towing; tongue weight; various weights I need to ensure are within range; should we carry items in the Jeep or the TAB; any recommendations are extremely welcome. This is our first travel trailer - purchased over a year ago but haven’t had the opportunity to experience it until now. Want to ensure the Jeep can safely tow and not cause any damage to the trailer or Jeep.
I appreciate your time and expertise
To keep tongue weight downI put a single Lithium 100 Ah battery in the compartment near the converter and I replaced the steel propane tank with a 17lb Viking lightweight tank. I usually carry two folding ebikes totaling 135# in the Jeep and I installed Air Lift 1000 airbags to keep the sag below 1"
The Air Lift 1000 airbags - can you explain? All this is so new to me
I have the 2021 wrangler unlimited Rubicon
The dealer installed an after market brake controller but would prefer Molar - will you post a pic of the controller in the dash?
a little nervous taking it on the road for our official first excursion
The Mopar brake controller fits in place of the 12V power jack in the dash: https://store.mopar.com/oem-parts/mopar-trailer-brake-controller-82215652ad
I am not aware of any special sequence when you change out the battery. Just turn off the battery switch and drop in the new battery. Be sure to get the polarity right. The Viking tank fills like any steel tank. You just need to find a dealer that fills tanks rather than exchanging them.
