need some help
jhprice
Member Posts: 5
2022 tab 320 cs-s boondock
Just got it ac works great after cools down about 30 minutes heat comes on and then get hot inside any sugestions have read the ac service book and it is on 30 amp shore power I did buy it used customer said needed bigger bed he was 6,3 so i could see that said the y only used it a couple weeks
note this has heat and Ac unit under bed and vents
Hi,
I'm guessing you have the Alde turned on in addition to the AC (Air 8) . Is that correct? It sound like you may have the AC and heat set points crossed. By that I mean you have the AC set to cool down to say 72F and maybe the heat set to something above that, say 72-74, which would cause the heat also to be on. Does that make sense?
Can you provide the set points you have for the AC and heat?
2025 360 CS
Southern Maryland -
I just planted my palm on my forehead I should have thought of that thanks
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
