Can’t see Dometic thermostat screen
crowsnest
Member Posts: 50
Is there a replacement for the completely illegible Dometic thermostat? It’s impossible to read under any conditions. The text is so small.
@crowsnest; Which make and model Fridge does your 400 have installed.
Believe you own a 2018 400 which had two different Fridge options.
Most Fridge model Parts Lists are available on-line with many replacement parts available from different web-sites. For example here is a typical Norcold Thermostat;
NR740/NR751'18 320 S, pitched axle, 3020HE; PNW based
I think they are asking about the Dometic A/C screen...
@crowsnest mine isn't small print...it's not very bright so sometimes seeing it is difficult for me. Maybe check with Dometic?
Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S0 -
Yes, I’m referring to the A/C. There are other brands that might work. I’ll check with Dometic. Thanksdsfdogs said:I think they are asking about the Dometic A/C screen...
@crowsnest mine isn't small print...it's not very bright so sometimes seeing it is difficult for me. Maybe check with Dometic?0 -
I found that shining a flashlight on the AC screen (day or night) allows me to read it. The problem is that I'm short--my taller husband can read it without a problem. I keep a little flashlight on a hook under the screen just for that purpose. The other fix for me is using a small folding step stool. The screen is at an odd angle for short people and it looks blank.0
I really dislike the Dometic thermostat. I have the same problem and can't see the LCD output. I would like to replace mine too. I'm not sure, but wouldn't any thermostat with a/c and heat pump option work? Having to use a flashlight does work but isn't ideal, now is it!2018 Tab 400 / 2015 ford F-150 2.7 EB0
I replaced the original thermostate with a Bluetooth version and use my Ipad to control the CoolCat
Dometic CT Single Zone Thermostat
The wiring is the same as the original. I believe it was four wires and two screws and then pair the Ipad and thermostat. It works great.
@GrayGhost do you have the sku or model number. I recall seeing the bluetooth version but with another part that goes near the Coolcat. I want only the bluetooth wall item.2019 T@B400
Southern California
Full-timer since 20190 -
The part is from Dometic. The part number is D7E 3316255000 BT CT T-STAT - COOL/FURNAC. I bought it at my local RV repair center, Richard's RV repair in Greer SC. I paid $112.39. The Dometic was an easy direct replacement. Just remember which wire goes in which slot.I recently saw this one Micro_Air EasyTouch RV Thermostat model number. RV 351. Part Number: ASY-351-X02. They have a black and white version. I l have not heard anything about this one, but it sounds good.
- 123 Dutchman and Vintage TaB Archives
- 961 Air Conditioning & Refrigeration
- 143 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 918 Tips & Tricks
