Does trailer have to be level when de-winterizing?
Getting ready to do this task.  My 2021 tab 320  needs to be pulled over to the water spicket and won't be level.  How much will this affect the de-winterizing process?
    edited April 2023
    At worst, the fresh water tank will not completely empty when you are done sanitizing.  As long as you have rinsed out the bleach water, you can then open the fresh water tank drain valve  and move it back to your storage spot, raise the tongue and it will help empty the tank.
  • SLJ
    SLJ Member Posts: 668
    The first time I drained water from my 2021 320S I got another gallon out of it when I tilted it back. To completely drain the gray tank I have to tilt it toward the drivers side.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
