The interior lights work on shore power but not on battery. The battery has been tested and is in very good shape. All fuses in the power center have been checked and are okay. I have been told that there is a fuse or circuit breaker between the battery and thd power center but cannot locate it. Does anyone have any ideas?
2014 CS, tie-dyed exterior, "Tabula Rasa" and 2009 T@da also tie-dyed, “Grateful”
0 ·
Once located you can test, if bad then you can decide on searching for a direct replacement or wiring in the newer 'automotive blade' fuse holders.
This thread has some discussion - - - T@da in-line battery fuse
Adventures: 56 Nights: 379 Towing Miles 47,220
