2015 T@b 320 AC condensation
dp150
Member Posts: 18
I am on the road with my T@b and experiencing a problem with AC condensation building up. When we have moved the last couple of time water has obviously been running out from the tray under the AC and onto the bench below. Is the drain behind the wall panel? What is the fix? I can see new water stain on the wood under the AC. Any info is appreciated.
Don & Michelle
2015 T@b S. 2017 Nissan Titan
For TaB model years with the Window A/C Unit the standard recommendation is to level the trailer with the hitch/coupler slightly lower than fore-aft level.
The Window A/C has a drain tube located near the wet-bath wall.
This thread has some pictures:
AC Condensation Leak
There are several other threads as well on the topic.'18 320 S, pitched axle, 3020HE; PNW based
Adventures: 59 Nights: 411 Towing Miles 50,3501 -
This thread has descriptions and photos of where the drain is: to the right of the AC compartment, toward the middle of the trailer. If the trailer is not slightly "tongue down" water cannot drain. Another possibility is a cracked "drain pan", the place where water collects before it drains.These is a search for threads about "ac drain pan" that will explain more about all of this issue.
Towed by 2014 Touareg TDi1 -
Thanks for the info. Love this groupDon & Michelle
2015 T@b S. 2017 Nissan Titan0 -
I had trouble with condensation leaking on my tab 320s also and found the dip pan cracked in the rear inside corner of the plastic drip pan. It was dificult to fix since the cracked corner in under the aluminum framing supporting the AC Unit.2019 T@B 320S0
