LED Light Strip Mishap
PhilW
Member Posts: 12
First time this year taking my 2019 320S Boondock out of the barn and totally forgot to review my checklist. As a result, I failed to clamp my 9' overhead door in place and ripped my LED strip (the long one on the front side roof) off. The threaded bolts pulled out of the roof and the light is not attached. I am in the process of scheduling an appointment with NuCamp for repair. I need to remove the light strip before I transport the unit. Does anyone know how the power cable is routed through the roof? The cable runs through the roof (over the bathroom).....I think it may run through the space where the water pump is located and then, perhaps, under the unit and back to the power panel under the seating. I prefer not to cut the cable if it can be avoided. :-(
Thanks, Phil
- 915 Tips & Tricks
