Adding a portable solar panel/w controller, can I spice the output to the MPPT battery cables.
DaveC
Member Posts: 83
I am adding a Renogy 100 watt panel with 20a controller to my 2023 400 with 1 100ah lithium battery. Based on other posts and manuals, the solar panel output should be connected to the +/- distribution block. The Victron MPPT 75 15 solar controller battery output goes to the distribution block. Can I connect the Renogy output to those wires or do I need to run separate wiring to the distribution block. I am putting the SAE connection in the Nautilus, so using existing wiring would be shorter.
2017 T@B 320 Outback 2023 400 BD (IdahoTabato) pushing a 2023 Volvo XC90
You will want to run separate wiring to the distribution block
Ken / 2023 Tab 400 “La Bolita” (39,000+ miles) / 2024 Toyota Sequoia1 -
The Victron solar controller wires are gauged to only handle the output from the MPPT unit. You need to run a second cable as elbolillo pointed out. Trying to use the existing MPPT wire connection to the battery distribution block could overload those wires snd cause a fire.
With all those connections to the distribution block, you should consider switching to busbars. Be sure to add a cover for the positive bar.
Rich2019 T@b 400
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
I like Blue Sea. Be sure to get the power busbar (like my picture) with the larger studs for battery cables, not just a busbar. SLJ's look good also.DaveC said:@Horigan, good suggestion. Looks like quality varies (at least on Amazon) do you have a brand recommendation? Thanks.Rich2019 T@b 400
If you have a controller on your panel you can also just attach the wires directly to the battery terminals and skip installing another bus bar.2021 T@b 400 BD "Vixen Gail"
Leadville Colorado1 -
I used the 3/8 which was fine for everything down to my 4 gauge battery connections. The buss bars I used also have smaller #8 screw connections for things like my Victron battery monitor so I don't have to try to fit small wires on a main post with the battery connections.2021 T@B 320 S Boondock
2025 Ford Ranger
The Finger Lakes of New York0
