Am I missing anything?
We are planning to order a 2016 T@B Max S in late September, hoping to get it in early April. The local dealer says they will build it any way I want so I'm putting together a list of what I want.
Options from the factory:
- Front window
- The metal platform and propane cover used on the Outback
- Neutral upholstery such as that used on the Outback or Tabitha
- A Maxxair Maxxfan Deluxe with manual opening
- Outside shower option (dog, gear, dishwashing, etc.)
I will also ask the dealer to install a battery cut off switch and a permanent surge protector, and mount the spare tire to the tongue.
Is there ANYTHING else that experienced T@B owners would recommend, either as factory options or as dealer added items?
  • jkjenn
    jkjenn Posts: 6,424
    Extra outlets and vent cover
  • Nomad
    Nomad Posts: 7,209
    I'd also add extra outlets - both AC and DC. The hardest thing is figuring out where you want them without living in the T@B and knowing what your routine will be.
    The standard battery is a group 24, I'd have them install a 27 with the appropriate frame to accommodate the larger battery box. Would give you a little extra breathing room.
  • Photomom
    Photomom Posts: 2,217
    Can anyone tell me how many 110V outlets LG T@Bs come with standard, and where they are located? We do travel with lots of gadgets, but all can be charged from 110V.
  • jkjenn
    jkjenn Posts: 6,424
    2 in the galley, 1 on the rear bench, 1 where the a/c plugs in (a/c plug takes up all of the space), and 2 outside. I would probably ask for 1 regular and one 12v USB combo on the rear shelf.
  • Lisa33
    Lisa33 Posts: 260
    Remember that 110 will only work on shore power.
    Lisa. 2008 T@DA, previously 2012 6x10 SS. Southeastern PA
  • Photomom
    Is there a cigarette lighter type outlet anywhere in the T@B? We do already have an inverter.
  • jkjenn
    jkjenn Posts: 6,424
    Yes, in the galley.
  • Photomom
    What exactly is a 12v USB combo outlet? Does it have a cigarette lighter type outlet in addition to the USB outlet?
    Also, will the USB outlets charge an iPad? iPad requires 5v at 12mw. I know the USB outlet in my Toyota won't charge my iPad.
  • Photomom
    Is this the combo outlet? http://www.westmarine.com/buy/west-marine--combination-12v-outlet-and-dual-usb-outlet--15830508 So LG will get one and install it where I want it?
  • Nomad
    Nomad Posts: 7,209
    Photomom - no, the T@B combo looks similar but has one cigarette lighter plug and a plug that can take two usb cords.
    My 2015 MaxS has a standard two plug AC (110) outlet and the DC combo over the counter (left side). Also a standard two plug AC and a cigarette lighter plug on the driver's side bench. And finally, two outlets outside on the passenger side.
  • bgualtieri
    bgualtieri Posts: 272
    My 2015 Max S (T@bitha) from May is as PXL describes.
    2015 T@b S Max | 2015 Jeep Wrangler Unlimited | was PHX East Valley, now Dallas!
  • Photomom
    Thanks much. I have to say the outlets over the sink may not be the best place to recharge expensive gadgets. And the one on the bench may not be accessible when the bed is made up. If I can get a 12v/USB outlet installed on the shelf behind the bed I will.
  • Nomad
    Nomad Posts: 7,209
    I was thinking on the side (or bottom) of the air conditioner cabinet might be a good spot since the cabinet is already wired. If the bench is up, the outlets on the shelf would be hard to get to.
  • Photomom
    That isn't a bad idea. Perhaps I can put something above the window valance where devices can rest while they're charging.
  • Nomad
    Nomad Posts: 7,209
    Or a device holder meant for a car mounted to the AC box also - Or, just set in the valance shelf.
  • Yes, yes, and yes to all of you.  If i could have one more thing in my 2016 tricked out standard Sofitel (zero compaints), it would be a combo 12v/110 outlet up high, near the AC, just above the valance.
  • ChanW
    ChanW Posts: 3,165
    edited August 2015
    Note that most USB outlets have a phantom draw of around 100-150mA or so, even when not being used, due to the electronics needed to convert 12v or 120v to 5v-DC.
    A cigarette-lighter-type outlet doesn't draw anything when not in use, so we use 12v USB car-type chargers, and plug them in only when needed.
    There are some nice small ones that don't protrude at all, and that put out the higher 2.1A power needed for tablets and smartphones. We also have one that's a double USB charger, with high output on one port.
    I've always had good luck with Boxwave:
    <a rel="nofollow" target="_blank" href="http://www.boxwave.com/samsung-galaxy-s5-travel-chargers/samsung-galaxy-s5-micro-high-current-car-charger-for-galaxy-s5/bwpdd/gwp-zwpg/">single USB: http://www.boxwave.com/samsung-galaxy-s5-travel-chargers/samsung-galaxy-s5-micro-high-current-car-charger-for-galaxy-s5/bwpdd/gwp-zwpg/</a><br><br><a rel="nofollow" target="_blank" href="http://www.boxwave.com/universal-dual-micro-high-current-car-charger/bwpd/wkv/">double USB: http://www.boxwave.com/universal-dual-micro-high-current-car-charger/bwpd/wkv/</a>
    I guess I'm saying you might want to avoid the built-in USB charger outlets, if you plan to boondock at all.
  • Verna
    Verna Posts: 6,876
    Thanks, Chan.  I didn't realize the USB chargers outlets had a phantom draw.  This changes what I'll install around the A/C unit.
  • RollingLagrima
    RollingLagrima Posts: 435
    edited November 2015
    I recenty added this gadget that has multiple. USB and 2 12v plugs. Inserted in one of them, in the pictures is a 12v battery meter.  All glowing BLUE to match my BLUE fridge fan switch and jensen.
