2004 Dutchmen Tab generator?
huffalumpy
Member Posts: 2
Hi, I'm new and own a 2004 Tab. I'm looking for a generator so I can use to power fridge and lights. I don't use the AC whatsoever. Some of the campsites that I stay at do not have electric hookup for me to use for basic energy. Any help is appreciated!
Thank you.
My tab runs on a 12V battery.
Thank you.
If you are only using the 12 VDC systems, and using propane to cool the fridge, you can upgrade to a lithium 12VDC battery, minimum of 100 amp.hrs. and add some portable solar panels to recharge the battery. If you camp for more than three days at a time, I would get 2 ea 100 amp.hr. lithium batteries (if the 100 amp. battery is not enough), and get two100 watt solar panels to charge them. This should keep the battery charged enough whilst camping. I do this with a TaB400, running the fridge off DC as well and have not run out of DC power yet.
Thank you so much Denny! I will look into the 100amp.hr. lithium batteries and solar panels. I appreciate your input.0
@huffalumpy, you are welcome. There are several discussions here about adding lithium batteries to a TaB320. Many take the opportunity to put the battery isnidemthenTaB under the seat bench, to keep,it out of low winter temps.
cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
- 143 Events & News
- 922 Introductions
- 411 Service/Maintenance & Recall Notices
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
