Replacing Jensen Television
Resa_tab
Member Posts: 7
Has anyone replaced their existing Jensen tv with another, non rv brand. I have a 2022 tab 400 bd. I am looking at a 32” smart (fire) insignia (Best Buy) tv that has three HDMI ports. Big questions are max weight on the wall mount, non 12v system (I think this is a big proven), and compatibility with Jensen sound system. Thanks!
Weight is 11.2 lbs0
Replaced the Jensen TV with a Samsung 27" monitor. It's not heavy, but I replaced the mount with something more rigid. We use it to stream from a Fire Stick, iPhone or DVD player through the HDMI port. The 27" take up the wall behind the bath. I would think that anything bigger would stick out.
edit: Should have noticed that this is for a 400 (not a 320), so not very relevant to you.
You also want a 12 volt one as I live in a hurricane area on the coast would not be without a 12 volt one. Art
2019 TaB 320 S Boondock Edge1 -
gulfarea said:You also want a 12 volt one as I live in a hurricane area on the coast would not be without a 12 volt one. Art
My Samsung came with a 14V power supply, but operates fine wired directly to the T@B's LiFePO4 batteries.
I put two Samsungs in my motorhome that ran on 12 volts. Look for the ones with the power brick on the cord. The back of the TV where the power cord plugs in should say 14V but they ran fine on the 12 volt RV battery system.
2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York2 -
Thanks. I’m glad there are options.0
Interesting. And people might also want to note that these days it’s easier find monitors under 42” than TVs, if you don’t need the tuner.SLJ said:I put two Samsungs in my motorhome that ran on 12 volts. Look for the ones with the power brick on the cord. The back of the TV where the power cord plugs in should say 14V but they ran fine on the 12 volt RV battery system.San Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Just put in 24 inch LG smart tv, fits in same space. 19 volt d/c from brick but cheap d/c booster runs it well. Used the optical input adapted to rca for dvd from Jensen. Bluetooth sound to Jensen works well.0
