Single or double sway bar?
Beenie
Beenie Member Posts: 21
I have a 2021 T&B 400 towed by a 2021 Jeep Grand Cherokee that can tow 6,000 pounds. I have a double sway right now and it is very heavy for a little 66 year old female to use. Will something like a Reese single sway bar be sufficient and safe to use?
  • AnOldUR
    AnOldUR Member Posts: 1,763
    edited January 2024
    Are you looking for a weight distribution hitch (WDH) or only anti sway? What you have is probably a WDH. They are only necessary if the weight on your hitch is causing swat. Otherwise the Reese friction sway bar will give you sway protection.
