Suction cup bike rack
xflatlander
Member Posts: 3
New to the community. Thanks for having me. I have used the threads here for research on the Tab trailers with great success. My discussion here, and I know that bike racks on the Tabs has been a very popular topic, but I had only come across one thread regarding the Sea Sucker suction cup racks and the use on on the trailer or the tow vehicle. What I hadn’t seen was a discussion about it being inside the trailer. I have a 2021Tab 320 CS-S and the rear area under the cabinets between the cushions has a great flat, smooth area for one of these racks. I decided to order a Rock Bros single bike rack and it fits great. So there is not enough room for 2 bikes inside the trailer and the 2 bike rack won’t fit on that surface anyway. Enclosed
are a couple of pics one with my road bike and one with my mountain bike as examples. There is a suction cup for the rear tire as well to help keep the bike more planted. That suction cup didn’t stay as well, though I did not clean the area as I was just trying it out. I have not tried this on a road trip yet so I have no real world experience with it but I suspect that this is going to work well. Anyone else try this yet?
are a couple of pics one with my road bike and one with my mountain bike as examples. There is a suction cup for the rear tire as well to help keep the bike more planted. That suction cup didn’t stay as well, though I did not clean the area as I was just trying it out. I have not tried this on a road trip yet so I have no real world experience with it but I suspect that this is going to work well. Anyone else try this yet? 1
Personally I would never rely on suction cups alone. Bike may become a destructive missile. You might consider some backup straps tied off to:
a. The table mount. Slide the dovetailed post in place and strap to that to limit sway and forward-back motion. Table mount is backed by 2x4 framing and is probably the most secure point of interior cabinetry.
b. Test the end panels of base cabinetry** and if sound, surface mount a pair of strap clips. Run a toothed-clamp nylon strap between them and take a wrap around the bike frame or wheel.
c. Unlike the walls, the floors normally have good screw holding power. You might screw a pair of flat laying tie down rings to floor up close to cabinets, if not a trip hazard. Test in a hidden spot for holding power. Use no more than one inch length screws.
We have various cargo tie downs in our 320s but keep bike upright in our truck bed.
**our cabinet ends are held poorly by pocket-hole screws.
2021 T@B 320S Boondock/ 2012 Tacoma 4 cylinder truck / 2023 Tacoma 6 cyl. truck1 -
I have used the set up above a few times. No problems. I even had my E mountain bike once. That was about a 5 hour trip to Moab. Hit train tracks hard and everything held great. I did check at every stop for food/fuel and never had to reset anything. Obviously this is not a good setup for two bikes. As a side note, I do have room for my battery powered cooler behind the road bike and then I plug that into the DC socket so it gets power all the way to the destination0
Thanks for sharing, good to know those types of mounts exist. I was thinking about transporting my bike inside the trailer, but I know me, and I know grease, and I know scuff marks from tires, and I know it's only a matter of time... lol. I finally ended up ordering a front hitch for my truck and when/if it ever comes in I'll post a pic of the end results on the forum somewhere.2025 Tab 320 S BD2024 Nissan Frontier0
