Roof solar advice sought
goforth
Member Posts: 8
Brought the tab 400 home from storage to perform maintenance (re-caulking of portal windows)I notice this cover is cracked. Would love help identifying the part so I can replace it.
Also appears the solar is starting to delaminate. Should I pull off this later or start to search for a new panel?y
Here's a source for the cover that I've used. Apply with 3M VHB double sided tape and seal with RV caulk. Self leveling probably won't work with that slope.
I would contact NuCamp Customer Support on the peeling. Some you can peel off the plastic, some you shouldn't.
https://www.amazon.com/Link-Solar-Weatherproof-Project-Campervan/dp/B0111RNZDY/ref=sr_1_3?crid=25GT9IVB6CD6R&dib=eyJ2IjoiMSJ9.7petST0zhnwSpicSFOqMUWsrmNUThr6McKtj6TN77F-H3UleHirzC2Ait32cGQUr5eSRA4j504g29VvyH-5b9jAVXGikGBr_dxRaXJE2wy04UOmgAyjsHyMGi1m6NycoRzz30bT0TIMzBOFPFX0WhFQxgt64zCWb7rx4oNK32Lsb2noNRY00vBRnXLbufA4aU_iWt3NLh0L1QFGLzuo1VhJamxkvsPiFhjlQxFSU_4E9C0jakoCcltVyTTXkxgD5_csQJk_BDmWoXUmTpnOGh5nViJgbfFnja0dxi9oXcVs.nadyfm9mkNNJUiCV6OjlIuEEu39Mty4Tnrvo6vzqRBs&dib_tag=se&keywords=Weatherproof%2BABS%2BSolar%2BDouble%2BCable%2BEntry%2BGland&qid=1711292378&s=lawn-garden&sprefix=weatherproof%2Babs%2Bsolar%2Bdouble%2Bcable%2Bentry%2Bgland%2B%2Clawngarden%2C140&sr=1-3&th=1
Rich2019 T@b 400
2025 Toyota Highlander 2.4L TurboBellingham WA0
