Shurflo water pump
PFanning
Member Posts: 1
In our 2021 320 CS, we found the water pump would continue to run after pressurizing. The Shurflo pump has an Allen wrench set screw on the pressure switch; turning it about 90 degrees clockwise (as viewed from above) solved the issue.
2
Thanks, I've never considered adjusting the pump.
Mine is mounted upside down . . . so adjusting will be a project day activity.
I did do some additional web-research and these two items might be helpful:
A] Good video on Adjusting Series 4000 Pump
B] Bits and pieces of the installation manual
Adventures: 61 Nights: 417 Towing Miles 51,0500
