what is this T@B 400 inverter supplying power to?
What is this rather large inverter that is installed in my 2021 400 Boondock supplying power to? The only thing I know about is the 110 outlet next to my bed that supplies 110volts, without shore power, on battery alone. Is there anything else?
Karen and Chris
2021 T@B 400, 2018 Land Cruiser
Dallas, Texas
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view.” Edward Abbey
  • Busted_11B
    Busted_11B Member Posts: 18
    Isn't that the inverter/charger? you need that in order to charge or use your battery
  • CruiserCamperChris
    CruiserCamperChris Member Posts: 93
    No, the charger is in the WFCCO under the sink. It does two things, converts 120 to 12 and charges the batteries. The blue inverter above is just an inverter.
    Karen and Chris
    Dallas, Texas
    @CruiserCamperChris
    Typical 400 Inverters supply the Bed Cubby and Bed Area Television outlets
    Like this:
    You should checkout the forum resources section that has an 'owners best knowledge' diagram of the 2020'ish 400 wiring at
    Best Guess 400 Electrical
  • Binghi
    Binghi Member Posts: 417
    I have a 2021 400 BD and am not aware of a television inverter outlet. Our television so far as I could tell was strictly DC powered, and there is no AC outlet anywhere near where it was located (I removed the television and replaced it with a DC charging station).
    The only inverter outlet in our trailer is in the bed cubby.
    @CruiserCamperChris the picture of your converter shows it to be a modified/improved Powermax converter/charger, not the stock WFCO.
  • Kevin_K
    Kevin_K Member Posts: 38
    @CruiserCamperChris yes, the only outlet the inverter supports is the bed cubby. I can also confirm that the power supply for the television is also 12 volts. I use it as a power supply for my rear view camera when traveling.
    2021 Tab400 boondock, 2019 Jeep Grand Cherokee Trailhawk
  • bergger
    @Binghi we also have a 2021 400 and yes the television is a 12v television and there is no 120v outlet under the television.  I believe they had that in earlier models, then removed it, then added it again to later models.  On ours the bedroom cubby is the only on powered by the inverter.  Having an inverter powered outlet under the television would be very nice and I've mulled around with adding one.
    2021 T@b 400 BD  "Vixen Gail"
    Leadville Colorado
  • KK1L
    KK1L Member Posts: 117
    This is the outlet under the TV in a 2023 T@B400...
    73 es God Bless de KK1L, Ron <><
    2023 T@B 400 Boondock "Running up a T@B"
    Jericho, VT
  • Binghi
    The inverter outlet I want is the one over the kitchen sink and counter. That would be great to power an electric kettle for coffee and tea when you’re boondocking.
  • Ghannan
    Ghannan Member Posts: 45
    2023 tab400  110v from inverter powers the cubby and TV 110 outlets only
