No city water?
New camper (to us, 2020 T@B 400); may have been winterized. City water hose is hooked up, yet nothing comes out of any of the faucets. Also, when we filled the freshwater tank and tried to run the pump, water came out of the city water inlet. We’re thinking it may have something to do with that spring loaded check valve right where you put the city water in, but scratching our heads over how this would be replaced?? 🧐
    For starters check out the First Post on this Thread {while on a 320S, same issue/principle}
    Water Coming Out Of City Water Inlet
    And Welcome to the nuCamp TAB Family.
  • KG400
    KG400 Member Posts: 2
    OK, thank you we had tried that with no fix to the problem, but for some reason when we filled the freshwater tank and used the pump to run water through the faucets, all of a sudden it was working again. Not sure what happened or if I’ll have to deal with it in the future, but at least I’ve got working water for this trip. 😂 TY.
