Isotherm C65 Elegance Just Moved In(stalled)
(Note - the bland panel to the right is temporary)
The work was much easier than anticipated. With all the options and configurations we elected to:
- install all the way "to the left"
- use dual power (AC (shorepower) & DC) with a battery disconnect switch
- inspired by @grassgd post for venting the compartment
- active fan(s) for venting air in and out of the compartment with diverters for directing airflow
Picts below show some of the aspects of the install.
The open cabinet shows the risers the fridge sits on.
The risers are aligned to help promote "intake" airflow from right lower T@B vent under the fridge to the left side of the cabinet/fridge. Also shown in the same picture is two "outflow" fans which pull the air from the left of the cabinet out the right upper T@B vent. Those two fans + the compressor fan (which is in the same flow direction) promotes the circular (facing clockwise) flow in, under, up, over and across the top, and out. (we used tissue paper to "watch" the flow).
One word about these risers is that they make install / remove of the new fridge slightly less "easy", as the fridge needs to "step up" and "step down" on the install / remove, but it works.
Nice install. I love ours. Very efficient. Our tow vehicle supplies enough power to run it and keep the batteries charged on the road. We have two 100ah lithium batteries and no longer have any worries about the fridge staying cool or running low on battery. On longer trips we keep most drinks in a separate cooler that gets opened and closed more often and typically doubles as a table between our chairs outside under the awning.2021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York0
