Entry step interchangable with the Boondock
We have a 2022 T@B 400. Can we replace the entrance step with the wider Boondock step?
  • MartyMoose007
    MartyMoose007 Member Posts: 3
    I have the same question.  The originated is too narrow to be safe for size 12 shoes!
  • den1jen
    den1jen Member Posts: 42
    Figured I would put this here regarding step. We noticed the step was extended couple of times while going down the road.
    i found they used lock washers and standard nuts which worked loose, I tightened them down and will replace with nylon lock nuts when we get back.
    2023 Tab 400 BD
    2023 Ram 1500 crew cab
  • SLJ
    SLJ Member Posts: 654
    Mine on my 2021 Boondock Step were all loose. Poor design. If I remember, I replaced six. NuCamp won't claim any responsibility. Their answer was "We don't make the step".
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
  • den1jen
    While on the surface not a big deal, I would think they mounted the steps and it rolled out of their factory so ultimately they are responsible.
    2023 Tab 400 BD
